The operation of my system, in BROAD STROKES would be as follows:
1. A water level sensor, either the one built into the dehumidifier or one I add, will signal the controller.
2. The controller will dispatch the vehicle, which has the hose end attached to it, to drive from its home location (beneath the reel) to position the hose end over the floor drain in the next room.
3. The controller will switch on the pump, via relay, and the pump will transfer the water down the hose into
