Improving The Artificial Muscles And Arm Exoskeleton
A project log for Zizzy: A Personal Robot Assistant
Zizzy is a personal robot prototype for people with limited mobility. It can talk, show emotions, and manipulate desktop objects.
Michael RoybalMichael Roybal 08/21/2016 at 18:370 Comments
I have just finished designing and testing new 3d printed artificial muscles to replace the previous ones. They occupy a slightly larger volume and are considerably stronger than the previous versions. In addition, the plugs that held them in place have been removed and they now slot into a shelf in a redesigned exoskeleton.
The new arm exoskeleton with the new artificial muscles now can rotate about 82 degrees which is an improvement over the 47 degrees of the previous arm configuration. For some reason, after many tries, I have not found a way to get a full 90 degrees of rotation with the muscles and hinge joints currently used.
I will post the STL files for the new muscles and arm exoskeleton as soon as the new arms have been fully installed.
