How to build a spectrometer
A project log for ramanPi - Raman Spectrometer
The open source 3D Printable Raman Spectrometer using a RaspberryPi and easy to find off the shelf components..
flcfl@C@ 09/11/2014 at 02:4541 Comments
Note: This log entry is a living document. I'll be updating this post to reflect the current configuration as time goes on.. There will also be a log at the end of the post noting modifications to the log, etc..
UPDATED-----> 09.23.2014
Ok.. It's been a lot of tweaking, and refining...  A lot of going over the design, fixing issues and overcoming problems..  But I have reached a pretty good point with the spectrometer design..  I managed to design this part of the system so it can be used completely independently from the rest of the raman setup..  You can print this portion, install the optics, setup the fairly simple electronics, configure the software, make some minor adjustments to the optics so they're properly aligned, hook it up to a PC (or the ramanPi) and get some work done!
This spectrometer should be about on par with what you'd get from an ocean optics commercial product... Well, at least as good as one could expect to get..  I might experiment a bit with better options than razor blades for the entrance slit..  But really, the diffraction grating is pretty much on par, the CCD is the same model... we should be getting some great results... I need to calibrate mine with a known light source... I have a neon ampoule, and a mercury vapor lamp...I'll be trying those out pretty soon..  In the mean time, I did a quick sample with a 532nm laser....  Here's the result from that...
I'd call that pretty clean considering it is my first try... and it's a cheap eBay handheld laser pointer... Unfortunately, we can't use that to calibrate the spectrometer...
HOW TO BUILD A SPECTROMETER - PART 1
I wanted to make this post a sort of how to for assembling the spectrometer... as much as I can anyway...  So, here's a quick guide...!
We start by loading up the files to print the plastic parts...
Set up the printer and start printing.... Wait a good 12-18 hours....
Keep an eye on it every once in a while...
And then you have the makings of quite a few lost weekends to come..
Once you've removed it from the printer... There's going to be a little cleanup required...  All the supports, and rough edges, screwholes and everything need to be free of debris, etc..
Once you get that all cleaned up.. Your spectrometer parts should look something like this...
Gather your other parts... The access port cover, the necessary screws, the diffraction grating..the collimating mirror, the focusing mirror...the mounts for the optics...your imaging board and the CCD board...
Here are the parts I designed this version of the spectrometer to use..and is what I am using in mine..
The diffraction grating...    Stock No. #43-216
The collimating mirror....    Stock No. #46-239
The focusing mirror...        Stock No. #43-471
I'll post the specifics on mounting the optics in their mounts soon, but for the moment, lets assume they're already mounted..
Go ahead an place the focusing mirror assembly in place and screw in the adjusting screws...
And always... make sure you're wearing proper gloves, and not to touch the surface of the optics!!!
Now, let's go ahead and place the collimating mirror assembly into place and screw it in...
Again, make sure to be very careful not to touch the surface!
Once that's in place, go ahead and place the diffraction grating assembly in...
BE EXTRA SUPER VERY MAJORLY CRAZY ULTRA CAREFUL NOT TO TOUCH THE DIFFRACTION GRATING SURFACE!!!!!!!!!!!!!!!  ANY CONTACT WILL RUIN IT... Just look at mine... :(  It fell on it's face on a very clean surface and is going to have to be replaced...
Here is what you should have at this point... A very nice start!
At this point, your optics are probably going to be way out of alignment.. We'll have to make sure they're all snug and aligned before we can use this thing for anything...
But we'll cover alignment in another project log as well... For now, let's follow through with getting this thing assembled!  Take your top and the access port cover...get the mounting screws........
Place the access cover over the access port and align the holes....
Place the screws in place and start tightening them!  I recommend an alternating pattern...
And there we have a spectrometer!! Almost ready for use!
We will cover placing the CCD board in another post as well... But this is where it goes.. :)
Looks great doesn't it???
Here's some sneak preview pictures of the alignment process...
If you can't tell, I'm pretty happy with how this part came out.....
I'll be picking up where I left off with the electronics and software now... And I am aiming for raman spectra by the end of the month!!  This is a quick little test I did (not calibrated) using some filters... More on this soon!!!
Does this look good on me?
LOL...
Edit:
A little better example of the 532nm laser... I think I had the beam misaligned on the first image... This one's not as strong, but I closed the entrance slit a tiny bit...
Update: 09.18.2014
Here is a much better signal from a better aligned laser in the test stand bolted to the side...
Update Log:
09.17.2014 - Started maintaining this post as a living document.. Added Title to start of instructions.
09.18.2014 - Added 532nm laser spectrum update at bottom...
09.23.2014 - New Logo
lilzzman71 wrote 03/01/2015 at 19:06 point
http://bwtek.com/spectrometer-part-4-the-optical-bench;
Holographic setup only needs 1 piece of grating.
Hi,   I found a piece of concave holographic grating for $90.
http://taomsun.en.alibaba.com/product/60016892882-800327480/A2_Holographic_concave_grating.html
This setup should save you quite a bit of money
fl@C@ wrote 03/03/2015 at 12:11 point
That link didn't work... But the grating I went with was only $135 from edmund optics..  In order to use a concave grating, you'll need to change the entire geometry of the spectrometer... and the way the scad file works to accommodate that...  I started with a concave grating as you might have read in some of the history and had no luck...
Let me know how it works!
lilzzman71 wrote 03/04/2015 at 19:21 point
OK, the link fixed. anyway, 1 concave grating=$90  versus your grating 130+70 (2 mirrors)=$200.  OK I try it out. I look for cheapest way to do it.
A. M. Aitken wrote 05/02/2015 at 22:57 point
If that holographic grating is not a flat field type then it will work badly with a linear sensor.  This has been covered in other comments.  It may not be sold anymore, I was only able to find details in google cache.
lilzzman71 wrote 02/26/2015 at 20:27 point
Is there an internet database already existed that contain reference data for different material we can compare our result against in order to help us determine the chemicals of the samples?  Or we have to start from scratch?
fl@C@ wrote 02/27/2015 at 01:08 point
There are several..  I have obtained permission for free access to one, and am working on as many others as I can...  Most of the larger ones are fairly expensive.  I'd be very happy if one of those companies allowed at least limited access for ramanPi users :)
I also have put some thought into a peer to peer network for ramanPi users to establish and contribute to a public open access database...
lilzzman71 wrote 02/26/2015 at 18:29 point
hi regarding to slit width, you mentioned you purchased a 10um one, is that matched with pixel width of the CCD?   according to reference 10um is the minimum, next is 25um, 50um, 100um and so on. It says the slit as wide as possible to increase throughput when optical condition is satisfied.
fl@C@ wrote 02/27/2015 at 01:06 point
The pixel width of the CCD I am using is something like 8um..  Oversimplified, a wider slit lets more light through, and decreases resolution....  I'd recommend some research before purchasing to decide which width is best for you...they're fairly expensive..
Try emailing me here http://www.meridian-scientific.com/contact.html and I'll answer your questions.. It's getting a little confusing with multiple questions in multiple places.. :)
lilzzman71 wrote 02/26/2015 at 18:04 point
Because you are using CT setup you don't need that expensive holographic grating.  Two typed grating, cheaper ruled grating and expensive holographic gratings.
The Concave Holographic bench setup using one piece of concave holographic grating instead of one planar grating and two mirrors of your Czerny-Turner setup.
Any reason not using concave holographic setting?
fl@C@ wrote 02/27/2015 at 00:58 point
Not entirely sure I understand your question... I started off with a holographic grating, there are a number of problems with it.  And if I understand correctly, the type of grating you are talking about is very expensive..
lilzzman71 wrote 02/25/2015 at 19:58 point
Great work! Have you seen those man held portable Raman Spectroscopy tool?  Why do you think it can be done so small space? Do you think you can do a portable one?  Its no more bigger than a handheld power drill tool?
fl@C@ wrote 02/26/2015 at 04:55 point
I have.  I haven't really looked into it too much yet, but I assume they use spectrometers based on devices like this http://www.hamamatsu.com/us/en/C12666MA.html Not sure what they do for temperature control or compensation, or a lot of other stuff yet....but A small laser diode, the right optics and that spectrometer along with an FPGA probably would do it..
I do have plans on creating a hand held unit..  I see no reason it can't be done... But after I finish this one and get the kits available to everyone..  :)
lilzzman71 wrote 02/25/2015 at 02:17 point
Why need a expensive diffraction grating material.  Youtube posters  have mentioned to use regular DVD material and cut it out for diffraction.
fl@C@ wrote 02/25/2015 at 08:20 point
It depends on what you want from the device.  Its mostly about spectral resolution.  I am in the process of designing 3 versions of this device..  Low Medium and Higher quality/price..  The lower quality version is probably going to end up with a transmission grating, not a slice of DVD...but still a lower priced grating similar to the way the DVD works. This version will also use the raspberryPi camera module and cost much less..   The Medium and High will still use reflection gratings because a lot of people want higher resolution and predictable results...  The high will probably be more temperature controlled, and offer metal parts, etc..
dleemiller wrote 04/26/2015 at 23:34 point
You might be able to do both in an LGL geometry. Thor has transmission gratings for $75, and regular pcx lenses are pretty cheap...though you may need/want achromats (and certainly if you were really trying to nail that 10um slit width). It would probably cost about half of the crossed czerny design with similar performance. If you wanted to go really cheap, you might be able to get away with a holographic film, but you'd want to make sure it was stretched and epoxied really flat over something like a microscope slide. It may not work very well, but if it did, it would be virtually free.
I've seen a design for an adjustable slit using razor blades and a micrometer knob. I bet I could come up with something for <$30.
A. M. Aitken wrote 05/02/2015 at 22:52 point
Aside from needing acromats another problem with a lens design is that every extra surface is also a reflector.
xmu234 wrote 12/23/2014 at 13:40 point
I really want to know how to design the position of the optical elements in your spectrometer.Looking forward to your reply, thank you
fl@C@ wrote 02/26/2015 at 04:49 point
Hi..  You might take a look at the github and look at the files for the spectrometer...  I am still in the process of refining it, but the spectrometer file basically designs itself.. You can alter the optics parameters and it will reshape and redesign the spectrometer based on your parts...  Hope that helps..
rova wrote 10/31/2014 at 16:26 point
Where can i get the blue prints so that i can print it my self?
nanobit wrote 09/16/2014 at 16:49 point
How do you compensate for the spectral response of the sensor?
fl@C@ wrote 09/17/2014 at 00:34 point
The Toshiba TCD1304DG has a pretty wide spectral response... http://www.spectronicdevices.com/pdf/TCD1304AP.pdf Especially for a raman system..
What type of compensation are you referring to? I don't plan on incorporating any coatings on the sensors optical surface, or cylindrical lenses, etc... Most everything else I imagine will be handled through software...
nanobit wrote 09/17/2014 at 19:37 point
Looking at that response, your spectrogram would be only accurate in the greens, the other regions will be distorted by the spectral response. Im no expert in optics, so software correction in these regions would be my choice too.
Also, how will you calibrate the sensor, to know which pixel represents a given wavelength? The laser on the last picture seems too wide to say 530something nm is at 2400something pixel...
fl@C@ wrote 09/17/2014 at 21:58 point
Distorted might be a little harsh, less sensitive perhaps.. This is the exact same sensor that $4-5000 spectrometers use. Some useful info can be found here that touches on some of your questions... http://bwtek.com/spectrometer-introduction/ Particularly here http://bwtek.com/spectrometer-part-5-spectral-resolution/ and possibly http://bwtek.com/spectrometer-part-4-the-optical-bench/ and definitely http://bwtek.com/spectrometer-part-3a-the-detector/ ....
This document has some very valuable information as well... It actually should answer most to all of these questions... http://oceanoptics.com//wp-content/uploads/USB4000-OEM-Data-Sheet.pdf (This spectrometer datasheet actually covers their usage of this exact sensor )
This document covers sensitivity using the TCD1304 in their USB4000 and HR4000 spectrometers... http://oceanoptics.com/wp-content/uploads/HR4000USB4000ShutterPerformanceinHWtrigger3.pdf
Calibration is done with a known light source.. Something like a mercury vapor lamp, or neon, etc... where the spectrum is well established.. you match that and so on... Here's a product made just for this http://oceanoptics.com/product/hg-1/ ....... It's also covered well here http://www.americanlaboratory.com/914-Application-Notes/1596-A-High-Precision-Calibration-Method-for-Spectrometers/ and if you like reading this stuff... here's another http://nvlpubs.nist.gov/nistpubs/jres/114/4/V114.N04.A02.pdf I think you're question also hits on spectral resolution...which is a big topic in itself..things like the entrance slit, diffraction grating etc.. have a large impact on that as well.. http://www.lightforminc.com/Spectral_Resolution/ or https://docs.google.com/presentation/d/1b7WFiBkPIzv3gN22CPkcTePRfbyhFV_yyaNz0sg4agY/edit#slide=id.p51 as well as the other info I provided demonstrates that too.. :)
Edit: Forgot to answer the last question..........
The laser is wide for several reasons.. Gary Firestone's comment below shows one good reason... also, the laser itself isn't perfect.. It's not going to emit at a specific 532nm wavelength, and not have some spillover, harmonics, etc.... Temperature, and a lot of other variables contribute to the width it emits... The 532nm Pass filter helps with this, only allowing 532nm light to pass through it (I wasn't using this filter for the above images), but that doesn't account for the issues Gary mentions...so there's going to be some..but software should be able to account for a lot of it, and that (and a number of other reasons) is why calibration is important... The documentation I provided above explains this pretty well too....particularly the datasheet on the USB4000...
Hope this helps!
peter jansen wrote 09/19/2014 at 03:09 point
I think what nanobit's mentioning is that the spectral response (the sensitivity of a pixel for different wavelengths) is different -- so for a 1mW 650nm monochromatic source the detector might give you a value of (say) 1000, and for the same intensity but different wavelength source (say 500nm), it might give you a different value -- say 500 or 1200. Normally you take this "spectral response curve" (top of page 10 in the datasheet) and multiply the value you've detected at a given wavelength by 1/the spectral response, to make it flat. So for example, for your detector, the peak sensitivity (1.0) is at 550nm, and were the detector pixel at 400nm to read (say) 1000, you should take that value and multiply it by 1/0.8 or 1.25 to make it as though it were as sensitive as the most sensitive wavelength (550nm) that your detector has. The fancy term for this is sometimes "removing the instrument function" so that the values you measure reflect the amount of light hitting the detector, and can be easily used be others in their spectral libraries. This also means that you'll be able to use other folks' spectral libraries, without wondering why when you measure the same thing the spectrum looks attenuated on either side. :)
fl@C@ wrote 09/19/2014 at 07:34 point
Thank you Peter... I fully agree... My main point was that this is a known factor, and is compensated for in software and is going to apply in most any detector you choose..
Karri Palovuori wrote 09/16/2014 at 14:14 point
In addition to alignment, the peaks might droop because of the multiple reflections from the CCD cover window. This is easy to verify since the amount (and side) of droop would depend on the angle i.e. wavelength. With very monochromatic sources (lasers) you should get interference banding as well.
fl@C@ wrote 09/17/2014 at 00:39 point
Agreed. I am just about finished printing the latest version of the casing which has the mount for the air slit I just received from Edmund... That and a test rig I made that mounts on the side and holds the laser, etc.. in place will allow for some better controlled conditions... I'll post the result as soon as possible.. Hopefully, I see what one would expect..rather than the hard to reproduce stuff I had until this point.. :)
er0sentha1 wrote 09/16/2014 at 01:08 point
One way to make a slit is to take a microscope cover slip. Place it over a candle to carbon coat it. Then use a sewing needle to scribe a line in the carbon. That is your slit. You have to handle the cover slip carefully so as not to dislodge any carbon. But it does make a nice clean slit.
fl@C@ wrote 09/16/2014 at 06:07 point
That sounds like an interesting method..! I wonder if you could coat that with a clear coat, or sandwich the carbon between two cover slips...?
I just ordered a 10 micron slit, hopefully it'll be here soon...
Pixel Pirate wrote 09/16/2014 at 00:43 point
Jesus Crust, that thing is a piece of art, do you think you could take pictures with a scale reference?
fl@C@ wrote 09/16/2014 at 06:03 point
Ha.. Thank you Pixel Pirate... Yes I will be sure to get something for scale in there... That was mentioned to me by a friend as well.. Until I get the pictures up... It's about 100mm wide, around 125mm long and maybe 65mm tall...if that helps... :)
I'll take a shot next to a ruler.. I don't know if a banana would be good.. lol
peter jansen wrote 09/13/2014 at 23:04 point
I wonder if you'll have to splurge and use a precision slit? Thor labs is sometimes a little cheaper than Edmonds: http://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=1464
It'll add ~$100 to the BOM, but at least then you'd have a known slit width, and be able to figure out what the spectral resolution should be with perfect alignment, so you'll know when to stop :)
fl@C@ wrote 09/14/2014 at 08:31 point
I have been thinking pretty much the same thing.. .. For the past two days actually, I have been racking my brain trying to come up with a reasonable approach.. I am not really satisfied with the razor blades, there's just too much room for variability.... And a printed slit is not an option, I tried a few different approaches to that and it's just not consistent.. and the widths are ridiculous..on top of the differences between printers, and the rest of a long list of reasons.. I wish there were a reproducible way for people to do this at home.. I haven't tried it yet, but I was wondering if an etched copper slit would be a reasonable consideration.. I haven't experimented in the past with how small you can reasonably do using photosensitive etching, etc... but I think ultimately you're probably right.. having a known slit width is very important.. When I originally started this project, I didn't really think I was going to get this in depth with it.. but the further I go... the more merit I see in it...
fl@C@ wrote 09/16/2014 at 06:10 point
I ordered a 10um slit... Hopefully that's about right.. All the reading I did said it should be slightly larger than the pixel on the CCD, which for the TCD1304DG is 8um by 200um.. I modified the 3d models, and I'm in the middle of setting up the printer to print an updated casing... Hopefully it gets here soon... the $40 for 1 business day shipping was almost half the cost of the slit! lol..
Untitled wrote 09/16/2014 at 16:37 point
"I am not really satisfied with the razor blades, there's just too much room for variability.... And a printed slit is not an option, I tried a few different approaches to that and it's just not consistent.. "
Actually, some amazing spectrometers like the Zeiss MMS1 use fiber optic bundles. You can do the same thing at home. Here's what I did. 1) Buy a bunch of fibers. 2) Lay them out on the table flat. 3) Place tape over them to keep them together. 4) Cut one end. Wala! you have a perfect slit. Now you can bundle the other end of fibers and couple them to a typical fiber optic connector (like most spectrometers).
fl@C@ wrote 09/17/2014 at 00:43 point
@Untitled... That's a pretty good idea.. Maybe something I look toward doing once I get the rest working, and am able to focus on tailoring the spectrometer portion for use outside the raman system... It is certainly something I want to accommodate for in the future.. I also want to make an adapter that bolts to the side of the spectrometer and has a fiber connector... Modularity.. :)
peter jansen wrote 09/19/2014 at 02:57 point
It's probably not an option for you since it will decrease your spectral resolution by an order of magnitude, but for the open mini spectrometer I experimented with laser cutting a slit into some thin material. Apparently on a really good machine and specific materials I'm told that you should be able to get down to ~100 microns, with ~200 microns a more easily attainable goal. The benefit is that it would take the slit cost from $100 down to a few dollars. :)
fl@C@ wrote 09/19/2014 at 07:41 point
I went ahead with the 10 micron slit... It seems to be working great actually.. I modified the model to allow for a 1.25mm by 25mm disc (mounted air slit) to be placed so people can experiment with different ideas.. As long as it's about the size of a quarter, it'll fit.. :) I might revisit the whole thing and experiment with different slits at a later date.. But the air slit is great and the contest date is looming... =)
peter jansen wrote 09/11/2014 at 19:03 point
Looking great! Poor grating, falling on its face! How are the optics held by the mounts, using some cement/glue?
Any idea why the spectrum of the laser pointer looks strange -- the right hand side just kind of drops instead of having a gaussian shape? Once it looks normal you can measure the FWHM/spectral resolution, and see how well you can tune it! (It looks like, continuing the curve you can kind of estimate that the FWHM might be around about 50 pixels, which would be about 5nm, if I'm estimating things correctly?)
fl@C@ wrote 09/11/2014 at 21:38 point
Thank you Peter..! Yes, I was sad when it fell.. But, it gave it's life for science... Currently, I am testing them using the clear 3M VHB double sided "tape"... I didn't want to cement them or glue them in place until I was confident on the final design.. I think I might be making a slight change to the diffraction grating mount too.. But eventually I'd like to find a decent cement or glue that won't attack the plastic..
The spectrum might look strange because I think I had an alignment issue.. I just posted an updated image that's a little (not much) better.. Through this bit, I've learned there are two things I need to do in the next day or two.. 1. Make a solid mount that mates to the side of the spectrometer for testing and calibration, and the 2nd is hang a connector on the imagingBoard that will control the laser pointer so I don't have to push the button and move it around while it's taking a sample... What I have now is a nightmare for alignment and consistency.. I'll be doing a series of posts.. This one was putting the parts together, another will be alignment, another for mounting the optics, another for calibration, etc... I'll try to get a better spectrum of the laser tonight.. Maybe I can get the software to count the width... that might be useful in itself..
