Build Instructions: Laser Emitter Assembly
A project log for ramanPi - Raman Spectrometer
The open source 3D Printable Raman Spectrometer using a RaspberryPi and easy to find off the shelf components..
fl@C@fl@C@ 09/25/2014 at 22:478 Comments
Note: This log entry is a living document. I'll be updating this post to reflect the current configuration as time goes on.. There will also be a log at the end of the post noting modifications to the log, etc..
UPDATED-----> 09.25.2014
This log entry will instruct you on building the Laser Emitter Assembly..
Tools Required:
Components Required:
Steps:
1. Print and clean up the plastic parts. Be sure to use the 3D printed part guidelines. All spurs and supports need to be cleaned as much as possible.
2. Grab the bottom half of the laser emitter assembly and the 532nm Pass Filter.
3. Make sure you are wearing the nitrile gloves and a pair of the white gloves over them and place the CVI 532nm bandpass interference filter one inch dia. # F10-532-4 into the bottom half of the laserEmitter Assembly and set aside for the moment..
NOTE: Make sure the surface mirror side is on the outside of the assembly!
4. Grab the laser emitter power supply.
5. Remove the screws from the cover and remove the cover.  Then remove the strain relief screws.
6. Once that is done, remove the laser emitter power cable.
7. Grab the top half of the laser emitter assembly and pass the connector end of the laser emitter power cable through the small hole towards the back from the inside to the outside..
8. Slide the laser emitter assembly top half down the cable and fit the emitter into the assembly.
9. Grab the bottom half of the assembly, gently place in on the laser emitter and make sure not to scratch the pass filter!  Then place the 4 M4 16mm screws in the screw holes.
10. Tighten the screws.
11. Grab the laser emitter power supply, the cover and its screws..
12. Place the cover back on the power supply and screw it on.
And that completes this section! Congratulations!
Set aside and move to next build!
You can close this tab or return to the build instructions here!
UPDATE LOG:
09.25.2014 - New Entry
kundidragon wrote 03/04/2015 at 19:25 point
https://imagizer.imageshack.us/v2/1110x372q90/912/VR0kNK.png
Here's the 532nm  laser module with fans and heatsink.
fl@C@ wrote 03/05/2015 at 01:53 point
I don't see much wrong with that option from a quick look..  I'm starting to look at methods to stabilize/control the temperature and monitor the output as well.  Haven't spent a lot of time on it but mostly it will be a peltier acting as a heating/cooling controlled with a pid using a ds18s20..  I haven't worked out the details on how I plan on monitoring/calibrating the laser, but one option might be to feed the laser through the bandpass and into the spectrometer directly (probably with a very tiny entrance slit) to measure the laserline frequency...or into another device...I haven't looked yet but there are some color sensors out there that might work...I just haven't read any datasheets to determine if they are accurate enough in this spectrum... Seems worth a look though..
kundidragon wrote 03/01/2015 at 18:37 point
not sure why the laser module needed to be bulky. Do you think type would work?  much smaller and cranking out 150mW.   https://imagizer.imageshack.us/v2/1025x215q90/661/VAX76P.png
fl@C@ wrote 03/03/2015 at 12:06 point
Laser line stability is important.  Temperature regulation is an important part of that... Thermal mass contributes and a large aluminum heatsink is a good way to facilitate that...  Also the power supply makes a good contribution, the laser I chose seemed like a good middle ground between cost and achieving as much a balance as seemed reasonable..
lilzzman71 wrote 02/25/2015 at 02:08 point
Hi,   I am a newbie. I think the setup is for advanced user. Like it didn't instruct me why it needs a bandpass filter for green at 532nm?  I mean the laser itself is already giving out only 532nm.  Maybe adding an IR filter instead.   Also Why need a laser module? Why not just a diode green laser at 150mW.  it's much smaller and cheaper.
fl@C@ wrote 02/25/2015 at 08:02 point
Hi..  The 532nm bandpass filter is to filter out everything except the 532nm light from the laser and to make the laserline (the width of the frequency not the beam) as narrow as possible...  An IR filter might be an added advantage since some of the less expensive laser diodes produce an IR beat as well from what I understand.  But not one instead of the other.  The laser used in this design is a green(532nm) diode laser at 150mw....  The purpose for using the version I chose is to ensure there is no variance (as much as possible) in the frequency (532nm)...  The entire system is dependent on color... It's a good idea to start of with a value that is known.. :)
For some of the background information you're looking for...such as where I explain why the bandpass is needed check here http://hackaday.io/post/2978 ...
lilzzman71 wrote 02/25/2015 at 19:43 point
thanks, great!  I am also wondering why visible violet laser at 430nm not used. it's more powerful and generate better resolution.
fl@C@ wrote 02/26/2015 at 04:41 point
Hi..  Yes, again it depends on what you want from the system...  430nm laser will more likely produce fluorescence... And that may be desirable, but can also be a major problem..
