controlBoard - schematic and board information
A project log for ramanPi - Raman Spectrometer
The open source 3D Printable Raman Spectrometer using a RaspberryPi and easy to find off the shelf components..
flcfl@C@ 09/26/2014 at 08:454 Comments
Note: This log entry is a living document. I'll be updating this post to reflect the current configuration as time goes on.. There will also be a log at the end of the post noting modifications to the log, etc..
UPDATED-----> 10.15.2014
This log entry is where I will keep current information regarding the schematic, board layout and other details about the imagingBoard electronics and firmware.. I will reference this log entry in the 'details' section of the project page.. This log entry will probably change from time to time to reflect the current status of the imagingBoard. If you're interested, it might be worth a bookmark..
The function of the controlBoard is as follows:
Here is what the current controlBoard looks like..
Here it is with the motors and some of the sensors...
The eagle files are now in the gitHub repository, and here is a rendering of the new PCB layout...
Top
Bottom
Here is the schematic..
The eagle files, and the firmware are located in the gitHub
The board consists of the Nucelo F401RE, two ULN2003 Stepper Motor Drivers, a BMP180 Barometric Pressure Sensor and an HIH-4030 Humidity Sensor..
UPDATE LOG:
09.17.2014 - Added living document info
10.08.2014 - Updated gitHub repository with new PCB design.. Included .studio files and images
10.08.2014 - Updated schematic and posted new PCB layout rendering
10.15.2014 - Updated schematic and posted new PCB layout rendering
lilzzman71 wrote 03/11/2015 at 01:12 point
Hi,
Possible to skip all these control boards and use Pi as the sole controller for the whole thing?    Theoretically, it should be doable.    This way you don't need some many boards and firmwares.
fl@C@ wrote 03/11/2015 at 01:54 point
Try emailing me here http://www.meridian-scientific.com/contact.html and I'll answer your questions.. It's getting a little confusing with multiple questions in multiple places.. :)
Mohamed Shamallakh wrote 01/13/2016 at 11:54 point
same question ,,, could you please give us the answer here
fl@C@ wrote 01/14/2016 at 22:02 point
Mohammed Shamallakh - Not really.  The Pi cannot perform the imaging, we are moving to an FPGA for that since even the microcontroller is not enough to handle the requirements.. The interface and control board could possibly, but the idea was to keep them modular but current development is heading toward integration of all the boards (except the imaging board) onto one which will reduce costs, etc.  The reason the imaging board is remaining separate is due to the fact the spectrometer portion will be able to operate as a stand alone device compatible with a regular ocean optics usb4000.  Some people asked why the Pi is involved at all, some ask why the boards are, ultimately choices were made during the contest but hopefully we find a decent balance. Thanks for your interest.!
