First batch (twice!)
A project log for Ugly SMD Adapters
Adapter PCBs for ugly or Manhattan breadboarding with SMD parts
ted-yapoTed Yapo 08/23/2016 at 17:261 Comment
The first batch of test boards arrived. Actually two batches did: USPS "misplaced" my first shipment for ten days, but found them again just after OSH Park rush-ordered a replacement set. Here they are:
I have a few projects that have been on hold until these arrived, so I'm excited to test them out. I'll post progress as I do.
These first boards must be glued to the copper-clad backplane. As a next step, I'm going to try some boards with three different ways of soldering to the plane:
It turns out that OSH Park supports castellations, so that sounds like the most promising approach, but I'd still like to test all three.
Next Up
As to which packages to support next, I'm running out of small DIP adapters. Here's a few I used this past weekend:
(Left) A 10-bit DAC is plugged in while I wait for a 12-bit unit to arrive; the adapter board makes mounting a socket on the plane easy. (Right) Half of a DIP8 adapter board makes a convenient mount for a 4-pin header for connections to a daughterboard.
Stay-Clean Boards
I used another trick on the above prototype to preserve the copper ground plane. I cleaned the copper clad with "Barkeeper's Friend," a scouring powder containing a fine abrasive, then rinsed it thoroughly. Once it dried, I spray painted it with a light coat of clear enamel. This coating protects the copper from corrosion, but is easy to solder through when connecting to the plane: it will keep the boards looking pretty for years to come. I read about this technique a few years ago on Charles Wenzel's site, but haven't been that good about actually doing it. I finally got motivated, and coated a few large pieces of copper-clad, so I can just cut them up with a shear as I need pre-coated pieces.
oshpark wrote 08/23/2016 at 18:16 point
Glad you finally got your boards!  We look forward to seeing them in action :)
