PCB has holes!
A project log for Simple Universal Motor Speed Controller
The goal of this project is to build a simple universal motor PID speed controller using a minimum number of components
rhysRhys 06/10/2014 at 00:450 Comments
Broke out the drill press and got the holes drilled in the PCB this evening.  Should have it populated tomorrow so I can do some testing of the firmware :)
