This is a software-only project. A simple C# program for controlling the Hameg HM8118.
Hameg 8118.exeFirst release, version 1.1.0.1. Get the most recent version on GitHub.octet-stream - 167.50 kB - 07/22/2016 at 14:10 |
Sorry, anyone know if it possible to save in a txt file the measures made by the HM8118 controlled remotely by this program? If so, please let me know. Many thanks!
Sorry, I just want to say that this program is able to save the measured data in an ASCII output. You should just select "log manual and sweep" in File and then select "File" -> "New" to get the windows where you can choose the output file. When the sweep is finished remember to select "File" -> "Close".
Thanks engunner!
