####Electronics
* 2 - Nema 17 stepmotors
* 1 - Controller board
* Smoothie firmware based board > 32Bit boards highly recommended
* AZSMZ Smoothieware compatible board. ( The one i use )
* Azteeg X5 Smoothieware compatible board
* Smoothieboard
* GRBL firmware based board
####Hardware
* 1 Kit - GT2 timing belt with pulleys
* 1 Kit -Ball bushing linear motion ( only 4 needed )
* 4 - 8mm Linear shaft. This will determine the size of the machine. Mind that you will need to make sure the belt length is enough >
* 330mm long
* 495mm Long
* 6 - 625 Bearing
* 4 - M5 x 25mm
* 4 - M5 Nut
* 4 - M3 x 20mm
* 4 - M3 x 25mm
* 4 - M3 x 10mm
* 12 - M3 Nut
* 4 - Washers
* 4 - Shim
* 10 - Zip ties small
* 1 - Lead screw or similar + Nut and washers
####Laser Module
* 2W Laser and Driver Jtech Photonics
