Toward a new board revision
A project log for Triggy - Sensor Node for Life Automation
A smart sensor Node to trigger an action on a smartphone each time a physical change is detected (temperature, displacement, click...)
vinchVinch 06/07/2018 at 14:590 Comments
The world of electronic components is evolving quickly: new chips appear, older ones disappear... I've recently discovered that the magnetic sensor (again) used in the version 0.3 of the board, a.k.a. the MAG3110, is discontinued. So I had to find a new component to replace it, otherwise no new board could be built. The most obvious choice was the LIS3MDL from STMicroelectronics. Not a big deal as not very different, but now I have to redesign the board and have it fabricated.
I'll post a new log when all this is done.
