New Fresh Recipes
A project log for Triggy - Sensor Node for Life Automation
A smart sensor Node to trigger an action on a smartphone each time a physical change is detected (temperature, displacement, click...)
vinchVinch 08/08/2016 at 19:290 Comments
Here are new IFTTT Recipes enabled by the Triggy module. More to come thanks to the expansion board...
This is only allowed by Triggy, thanks to its size: stick a module on the cat flap, and get notified when it moves, i.e. when your cat is entering or leaving the house.
With a module on your guitar, you can automatically inform your friends on Twitter or any other social network that you start playing, moving the guitar from its regular position.
Never forget to close a door or window for the night. Every day at 10 pm, you will receive a notification if the "open" position is detected.
