Android app changes
A project log for Triggy - Sensor Node for Life Automation
A smart sensor Node to trigger an action on a smartphone each time a physical change is detected (temperature, displacement, click...)
vinchVinch 11/12/2016 at 08:370 Comments
Triggy Hub Android application is being heavily modified to enrich the possiblities. I wanted to make the system less dependent on IFTTT, for those who don't want to use this service. In fact, most of the time the user wants to be informed of an event (when a door opens, when it rains, when the temperature goes too low etc ...) This can be done with a notification or a kind of alarm. Moreover, notifications could be pushed to other devices with third party applications.
So now it will be possible to create rules (local, not IFTTT) to run on the Android device. When an event is detected, one could decide to send a notification, play a sound, mute/unmute the phone, turn on/off the WiFi (any other idea ?) All this without internet connection required, but of course the phone must be in the BLE range of the Triggy module which generates the event.
