3D Printed Enclosure
A project log for Triggy - Sensor Node for Life Automation
A smart sensor Node to trigger an action on a smartphone each time a physical change is detected (temperature, displacement, click...)
vinchVinch 08/15/2017 at 21:120 Comments
It's a new step for the Triggy project: a decent custom enclosure for the board. This plastic enclosure replaces the previous paper-made enclosure. It's less customizable and a bit more expensive but far more robust and gives a finished look. The Triggy Tag can also be safely let outside, e.g. for rain sensing or in the pocket.
This enclosure is the result of several (a lot of) iterations with my personal FDM 3D printer. I used only PLA material for this prototype. The last version (on the pictures below) has been obtained on an SLA printer.
The final enclosure, in black and white versionsEnclosure is made of two parts. Internal faces viewThe enclosure with the board inside
