Stage two: desgining the flight controller
A project log for Unique mini quadcopter
fully designed mini quadcopter for special applications unique body, microcontroller and flight controller software
bennyBenny 08/01/2016 at 09:325 Comments
I have started to design all the components into a PCB with all the sensors tha i could of think of that will be usefull. I am going to mill in using the othermill so i had to make the wires spread apart, the red wires will be connected manually since i have only one sided PCB's.
** I would love to hear you thoughts, if you have any ideas for new sensors or any suggestion please let me know. (all the component are listed in the project page).
K.C. Lee wrote 08/01/2016 at 11:55 point
Missing 2nd pad for jumpers to GY91 connector, I2C.  Those pads would be needed if you want jumpers on component (top) side.
I would use thicker trace and larger pads to through hole connectors as they see more mechanical stress when board flexes under vibrations.
Benny wrote 08/01/2016 at 14:46 point
Thank you for the advices!
I have enlarged all the traces as you suggested, but not the pads (since that cause me a lot problems unfortunately) maybe you knowa pre-made library that I can use?
I didnt understood what you said about the jumpers, are you suggested adding jumpers to the GY91 I2C pins so i could disconnect them if I wish so?
K.C. Lee wrote 08/01/2016 at 16:30 point
Are you using eagle cad?  Pinhead is the name of the library.  They have elongated pads in the library and the extra copper are should help with homebrew PCB.
K.C. Lee wrote 08/01/2016 at 16:23 point
You might also want to move these two vias down as they will be interfering with your 90 degrees header.
Similarly, Shifter_In and out are in the shadow of the two connectors.
Benny wrote 08/02/2016 at 19:48 point
Yes, I am using eagle and I have used the Pinhead library.
I managed to enlarge all the pads as you told me.
I didn't knew that component represent 90 degree header, I gonna use normal header in there and the other connection is raised over the board so I dont think I will have a problem connecting it.
Thanks for sharing from your experience!
