Hackaday.io Hackaday.io
Sign up Log in
ESP Soil Moisture Sensor
ESP8266 based soil moisture sensor Wi-Fi enabled.
yancanyancan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
17.5k views
6 comments
132 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
17.5k
6
132
76
Team (1)
  • yancanyancan
Join this project's team
  • Source Code
  • Wiki
  • Sale on Tindie
  • Rev 2.1 on sale
completed project
hardware
ESP8266 wifi sensor
This project was created on 07/25/2016 and last updated 9 years ago.
Description
ESP8266 based soil moisture sensor Wi-Fi enabled. Also provide ambient temperature and humidity sensor. At the sensor's heart is an ESP8266 WiFi microcontroller clocked at 80 MHz and at 3.3V logic. This microcontroller contains a Tensilica chip core as well as a full WiFi stack. You can program the microcontroller using the Arduino IDE for an easy-to-run Internet of Things core. You can use ESP8266 flasher that an upload code at a blistering 115200 baud for fast development time. It also has auto-reset so no noodling with pins and reset button pressings. The sensor can upload sensor datas to remote server. We provided example code for uploading to thingspeak. == Hardware == * ESP-12F module x 1 * Button x 1 * Programming pinouts * Red led x 1 * DHT11 temperature & humidity sensor x 1 * Soil moisture sensor x 1 * AA Battery holder x 1 * Measures 35mm x 157mm The project is modifying of the I2C Moisture Sensor project from Miceuz. Thanks for his source code
Project Logs
Collapse
  • Minor update for rev 2.1
    yancan • 10/11/2016 at 08:54 • 0 comments
    Add a switch for measuring battery voltage and sensor voltage
  • ESP soil moisture sensor V2.1
    yancan • 08/31/2016 at 08:27 • 0 comments
    New sensor with full GPIO. Replace DHT11 with tmp112
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
pit.grandy wrote 02/03/2019 at 21:13 • point
Hello, is it possible to set up the sensor with ESPeasy?
Brandon Piner wrote 10/12/2017 at 11:25 • point
How well is your capacitive probe working? Are you willing to share the PCB design or even just the probe part?
Grigory Kolchanov wrote 12/12/2016 at 15:26 • point
in the commentary sneaked error "not low and high illumination"
Grigory Kolchanov wrote 12/12/2016 at 15:24 • point
Good afternoon. Found your project on Google, very interested, but I think the design is wrong. So this device is supposed to be used in places with low light, I propose to use a solar panel and small battery. Indirectly, the current from the solar panel, it is possible to measure the illuminance of daylight and in the greenhouse to control the operation of artificial lighting. In the fall, for a long time, light to report on the pollution of solar panels. Thus, I propose to make this device in the form of a flower on a long stem (sunflower) in which to place the soil moisture sensor in the puck inflorescences have a sandwich top to bottom: the solar panel charges the battery and the sensor of temperature and humidity. Flower petals of translucent plastic material and highlight them with different colors depending on the values of the sensors and their readings, customizable from within the app or on the sensor page ( beautifully, clearly and recycle excess power). Thank you for your attention.
Rene wrote 11/02/2016 at 12:07 • point
Hi! I guess you are using capacitive moisture probing? Could you provide some schematics and code?
Thanks for sharing!
yancan wrote 11/02/2016 at 14:38 • point
Yes. It's capacitive moisture probing. Please check the link for schematic and code.
https://github.com/AprilBrother/esp-soil-moisture-sensor
The 2018 Hackaday Prize
This is more than just a temperature/humidity sensor with an OLED screen - it is a multi-sensor platform for all your ha sensor needs!
Project Owner Contributor
Kube Multi Sensor Platform
b-kB K
In this project, we have used a hall sensor that is able to detect a magnet and also the pole of the magnet.
Interfacing Hall Effect Sensor with Arduino
hiotronhIOTron
Soil moisture sensor Wi-Fi enabled. It's based on Espressif's ESP32 S2 SoC and uses capacitive moisture probing.
April Soil Moisture Sensor
yancanyancan
A flexible web app for monitoring sensor data
Home Sensor Monitor
ryan-gassRyan Gass
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP Soil Moisture Sensor", please tell us the reason.
Send message
Remove Member
