Chassis Grounding
A project log for CNC Plasma Table
Plasma Cutter + CNC Table + Auto Load/Unload = Tool to build other projects faster
willbadenwillbaden 08/05/2016 at 22:190 Comments
Trying to adhere to Hypotherms grounding suggestions the following grounding methods were loosely followed. Ground bar on the machine chassis that individually connects to the Y, X and Z axis.
The Chassis ground bar also grounds out the work ground lead from the plasma cutter.
Which is also attached to a 4' ground rod right beside the machine.
