Simple Test
A project log for WICE-4M
Leap Electronics WICE-4M EPROM Emulator Reverse Engineered
forthnutterforthnutter 05/29/2017 at 13:590 Comments
Decided to do a test run to see if the DIL Plugs work and to see if WICE-4M is still working.
First plugged WICE-4M into my Applix 1616 .
Handy box to sit WICE-4M.
Run an old PC with Parallel port, did want to remove XP so used a Megabuild of Dropbox.
Fired up WICE-4M, started up Dropbox, started up wice-4m software in Dropbox and it all worked.
Loaded memory with Applix 1616 OS ROM. Port A has even address and Port B has odd address send to WICE, Turned on the Applix 1616 and BOOM it started.
Now on to the next stage !!!
