I have need for speed
A project log for WICE-4M
Leap Electronics WICE-4M EPROM Emulator Reverse Engineered
forthnutterforthnutter 03/29/2021 at 05:480 Comments
Have been working on getting some routines I had running in spin to work in Propeller Assembly, So far so good, I basic read a byte write a byte, read and write a byte with increment. The speed is still not to my satisfaction as of yet. Might try to do 16 bit and 32 bit read and writes that will get some things moving.
