• Magnetic speedsensors
    bram07/27/2016 at 15:06 0 comments
    Today I added the magnets and hall effect sensor to the motors. On every quarter of the wheel is a magnet that I could detect with the hall effect sensor to calculate the distance traveled. I use the 49E linear hall effect sensor this sensor outputs a analog value that changes when the magnetic field around it changes
