Cuhode!
A project log for Arduino Licorice Launcher
Voice Activated, Room Tracking, Catapult Launching, Magazine Reloading, Arduino Licorice Launcher
Vije MillerVije Miller 09/08/2016 at 18:350 Comments
Huge shout out to http://robowarner.com/portfolio/radio-homing-robot-diy/ for his RF tracking system which was adapted in to this needless novelty project. Calibration is 10% software and 90% hardware. Pay specific attention to some of the tips on that page because...actually...actually I wouldn't recommend this method at all. It was a nightmare. A g d nightmare...but good to know.
// Arduino Licorice Launcher @TVMiller
// RF Tracking @ Warner K. robowarner.com
#include <EEPROM.h>
#include <Servo.h>
// Centering
// Too small adjusts too frequently
// Too large will pass over signal
#define buffering 26
// Output Pin
#define ANT_WAVEFORM_OUT 8
// Input Pin
#define SPEAKER_FROM_WALKIETALKIE A1
// Calibration Pin
#define CALIBRATE_IN 11
// Variables
uint16_t caliset = 0;
uint16_t voltage = 0;
int state = 1;
// Servo Assignment
Servo turn;
int turnpin = 6;
Servo loader;
int loaderpin = 9;
Servo fire;
int firepin = 10;
Servo arm;
int arm = 11;
// LED Pins
int red = 3;
int blue = 4;
void setup() {
  analogReference(DEFAULT);
  turn.attach(turnpin);
  loader.attach(loaderpin);
  fire.attach(firepin);
  arm.attach(armpin);
  pinMode(red, OUTPUT);
  pinMode(blue, OUTPUT);
  digitalWrite(red, LOW);
  digitalWrite(blue, LOW);
  Serial.begin(9600);
  delay(6000); // Allow Power Up
  pinMode(ANT_WAVEFORM_OUT, OUTPUT);
  pinMode(SPEAKER_FROM_WALKIETALKIE, INPUT);
  pinMode(CALIBRATE_IN, INPUT);
  digitalWrite(CALIBRATE_IN, HIGH);
  // Read EEPROM
  byte HByte =  EEPROM.read(1);
  byte LByte =  EEPROM.read(2);
  caliset = word(HByte, LByte);
  Serial.print("EEPROM Calibration number: ");
  Serial.println(caliset);
  // Calibration Check and Delay
  // Aim Receiver and Clear Area
  if (digitalRead(CALIBRATE_IN) == LOW) {
    delay(10000);
void loop() {
  if (state == 1) {
    // Engage Licorice Weapon
    digitalWrite(red, HIGH);
    // Trigger Position Open
    fire.write(45);
    delay(1000);
    // Arm Launcher
    arm.write(180);
    delay(1500);
    // Lock Trigger
    fire.write(90);
    // Load Launcher
    loader.write(180);
    delay(330);
    // Stall Position
    loader.write(88);
    // Remove Arm
    arm.write(40);
    // Licorice Launcher is Hot
    digitalWrite(blue, HIGH);
    state = 2;
  } else {
    // Hold for Command from JACOB
    if (Serial.available()) {
      char ser = Serial.read();
      switch (ser) {
        case 'L':
          load();
          break;
        case 'F':
          fire();
          break;
void load() {
  // Load Launcher
  loader.write(180);
  delay(330);
  loader.write(88);
void fire() {
  // Antenna Switching Waveform
  digitalWrite(ANT_WAVEFORM_OUT, HIGH);
  delay(1);
  digitalWrite(ANT_WAVEFORM_OUT, LOW);
  delay(1);
  delay(1);
  delay(1);
  delay(1);
  delay(1);
  delay(1);
  delay(1);
  // Read Speaker Voltage
  voltage = analogRead(SPEAKER_FROM_WALKIETALKIE);
  // If in Calibration Mode
  // Store to EEPROM
    caliset = voltage;
    byte HByte = highByte(caliset);
    byte LByte = lowByte(caliset);
    EEPROM.write(1, HByte);
    EEPROM.write(2, LByte);
    delay(5000);
    endprogram();
  // Stall Turning
  if (voltage > (caliset - buffering) && voltage < (caliset + buffering)) {
    // Fire
    launch();
  // Turn Left
  if (voltage > (caliset + buffering)) {
    turn.write(180);
    delay(15);
    Serial.print("In, Cal\t");
    Serial.print(voltage);
    Serial.print("\t");
    // Return Cycle
    fire();
  // Turn Right
  if (voltage < (caliset - buffering)) {
    turn.write(0);
    delay(15);
    Serial.print("\t");
    // Return Cycle
    fire();
  delay(5);
  Serial.print("\t");
void launch() {
  // Release Trigger
  fire.write(45);
  delay(1000);
  // Reset
  state = 1;
  break;
void endprogram() {
  Serial.print("Calibrated to: ");
  Serial.print(caliset);
loopy:
  goto loopy;
