Avalon bus-master peripheral driving bus-slaves (with HPS read-out and control)
-- External bus to Avalon Bridge
Student generated modules will need to be Avalon bus-slaves when controlled by the HPS, but under some conditions will need to be bus-masters. For instance, building a module which writes directly to the VGA interface would require a bus-master ability. The first example uses the University Progam External Bus to Avalon Bridge (EBAB) module as a bus-master which addresses either the LEDs or the HEX display to display numbers set on the toggle switches, and with a write-enable using ~KEY[0]. The HPS C-code reads and displays the SW and KEY peripherials. The Qsys layout has just the HPS, parallel ports for the LEDs, HEX display, switches, and buttons, and the EBAB module. The LEDs and HEX display are hooked to the external-to-avalon master. The SW and KEY are hooked to the HPS h2f_lw_axi_master. (top-level, hex decoder, project ZIP). This code ignores the Avalon ACK bit and does not read any data.
-- Controlling the bus-master from the HPS
In the second example, the HPS uses a keyboard command interface to choose the HEX or LED device address which is used by the EBAB. The FPGA side has a small state machine which counts time and uses the EBAB to display the count on the HEX or LED devices. The state machine also handles the bus-write setup and waits for the Avalon bus ACK. The Qsys layout converts the switch PIO into an output getting data from the HPS light-weight bus. This new output is used for the device address by the EBAB. (top-level, project ZIP). This example is a model of how a hardware computational unit might be controlled by the HPS and interact with other bus-attached peripherials. The bus transaction from EBAB to HEX display PIO takes two cycles (write, ACK). I tested up to 100 MHz state machine rate, for a bus rate of 50 million/sec.
-- The logical sequence is: A C-program outputs a bus address to the h2f_lw_axi_master address (of the ARM) which is mapped to a PIO unit on the Avalon bus. The PIO unit exports the address value to the FPGA fabric, which also contains the EBAB. The EBAB uses the address (from the PIO) to set its own write address back onto the Avalon bus.
-- Multiple bus-masters to one bus-slave
The Qsys bus generator constructs arbitration hardware for various configurations of masters and slaves. I wanted to test the operation of multiple bus-masters talking to one bus-slave. The previous example was extended to have two EBAB units, one controlled as before with its bus address controlled by a C program. The other was set to always write to the HEX display. The phase of the write-clock was set up so that they write at different times. Each bus-master counts at different rates. The counts are displayed on the HEX displays and for bus-master one, on the LEDs, when chosen. The Qsys layout shows that both the EBAB masters connect to the HEX display. (top-level, project ZIP).
-- A modification of the top-level module changes the bus request rate to 3.1 MHz, uses the SW input to set the delay between bus write-requests, and puts the two write-requests and the two ACK bits on the GPIO_0 port for view on an oscilloscope. If the separation is zero and addresses are set to the same bus_slave, then one write-request is stretched to two cycles (top trace) while the bus is busy with the other. If two different bus-slaves are addressed by the two bus-masters, or the time between write-requests is one cycle or more, then there is no collision and the write-requests are each one state-machine cycle long. Synchronization in the bus-master state machines depends on reading the ACK bits returned from the Avalon bus. Which write-request actually gets stretched, when they are on the same cycle, seems to be randomly determined by race-conditions.
-- Video display bus_master with HPS
A bus-master to control video display is useful for many projects. Interfacing to the University video suite is challanging because the documentation is scattered or non-existant. The Qsys layout shows the connections to the bus-master at the bottom. You can see in the Qsys layout that both SDRAM and on-chip RAM are used. Both are necessary, but I am not sure how they are related. The interface I finally came up with can write pixels at about 6.1 megapixels/sec, at 640x480 resolution. I had to phase-lock the write cycle to the VGA_BLANK_N signal to avoid confilct with the VGA read cycle. I am not sure why the HPS program does not need to do that. The demo hardware writes a large blue rectangle a the top of the screen (as a background for text drawn by the HPS), then a slowly moving, 8-bit color map, then a diagonal line, and leaves a space at the bottom of the screen for a rectangle drawn by the HPS. The Avalon bus handles contention between the HPS and my bus-master so that graphics from the FPGA fabric can be merged with HPS graphics by simply writing the pixels. In this example, the text overlay is controlled only by the HPS. (top-level module, project ZIP, test image).
