Some tests
A project log for Programmable Air
A hardware kit to experiment with inflatable and vacuum based soft robotics.
amitabh-shrivastavaAmitabh Shrivastava 04/22/2018 at 00:450 Comments
I'm still having issues with the 2SMPP03 pressure sensor. But I went ahead and used the motors and valves to make some simple projects.
Basic pick and place:
Universal Vacuum Gripper
The next step is to use an instrumentation op-amp or HX711 to get pressure readings from SMPP-03.
