The new linear servo approach uses a flexible metal band which when bent into shape gets sturdy and still can be rolled up on a drum (cylinder)
I am using only standard parts and electronics such as the ATTiny and a DC gear-motor. (the schematics can be found in the pictures)
STL-Files will be published soon!
A motion study can be found here: <a href="https://www.youtube.com/watch?v=2p7mIsCNFCA" target="_blank">https://www.youtube.com/watch?v=2p7mIsCNFCA</a>
and here: <a href="https://www.youtube.com/watch?v=T9Sq1TAgjSc" target="_blank">https://www.youtube.com/watch?v=T9Sq1TAgjSc</a>
3D-printed parts where ordered on Itead Studio <a href="http://www.itead.cc" target="_blank">www.itead.cc</a>
Details
- Gear Motor: Precision Microdrives Model 201-109 (30 rpm)
This is a great concept. It inspired me to make a version with two strips of metal to strengthen against buckling. It uses hook and loop (velcro) to keep the bands connected when they're extended and each strip stores on its own drum, connected by a gear on each drum to maintain alignment. My prototype needs a curved enclosure to ensure that the metal strip extends rather than opening the winding wider. Will send a picture if I can.
Also, have a look at this system which uses a similar principle to make poles for antennae and tripods http://www.rolatube-expeditionary-systems.com/
