board_mount_test_6.stl
RAMPS+Arduino Mega board adapter to replicator 2
Model file
Standard Tesselated Geometry - 348.86 kB - 08/08/2016 at 20:15
Download
board_mount_adapter.123dx
Design file
123dx - 67.39 kB - 08/08/2016 at 20:15
Download
lcd_mount_test_5.stl
mount adapter for the LCD, used alongside the case for the LCD
Standard Tesselated Geometry - 290.12 kB - 08/03/2016 at 17:26
Download
lcd_mount.123dx
123dx - 44.68 kB - 08/03/2016 at 17:26
Download
test_ramps.ino
A simple program to test RAMPS 1.4 boards
ino - 3.18 kB - 08/01/2016 at 19:56
Download
pins.h
Here the only change is to set FAN_PIN to -1 so I can use the EXTRUDER_AUTO_FAN feature with PIN 9
h - 79.20 kB - 08/01/2016 at 18:30
Download
Configuration.h
Configuration for Replicator 2 using RAMPS 1.4
h - 35.20 kB - 08/01/2016 at 18:30
Download
Configuration_adv.h
h - 21.17 kB - 08/01/2016 at 18:30
Download
