Mapping out the connections
A project log for Replicator K
Updating my Makerbot Replicator 2 with up to date features
uriel-katzUriel Katz 08/01/2016 at 19:140 Comments
I read quite a bit in order to get this right. First I needed to understand how a RAMPS 1.4 board is typically connected - that information can be found here.
Next I needed to map the connectors in the mightyboard (My bot uses Rev-H):
Connectors in this picture:
In the end the connectors that I need were: steppers, endstops, extruder
