First go at understanding the building code for a passive build home
DSC00006.JPGFraming the window and door liners in the 20in/508mm thick double wall constructionJPEG Image - 3.31 MB - 05/21/2018 at 02:43 |
hot water lines in the insulation 012.JPGinto woodworking jigs, and more jigs, table saw safety and more seumas2 has about 400 videos on viyoutubeJPEG Image - 308.45 kB - 04/14/2018 at 00:06 |
hot water lines in the insulation 019.JPGused a straight edge with the routerJPEG Image - 607.21 kB - 04/14/2018 at 00:05 |
hot water lines in the insulation 037.JPGsimple INNOVATIVE router idea by George KJPEG Image - 524.57 kB - 04/14/2018 at 00:02 |
passive 66 001.JPGused a router with an 1in./25mm bit to channel in the water lines, blue coded for the cold/ red coded for the hotJPEG Image - 643.29 kB - 04/13/2018 at 23:59 |
That's an interesting project I have to say but I prefer an already build apartment by professionals. I recently found this resource https://1newhomes.com/new-homes/ and maybe you can take some inspiration from the new houses in London. Anyway, I hope that your building will be strong enough to stand for the next few decades (or even more).
