DSC00006.JPGFraming the window and door liners in the 20in/508mm thick double wall constructionJPEG Image - 3.31 MB - 05/21/2018 at 02:43 |
hot water lines in the insulation 012.JPGinto woodworking jigs, and more jigs, table saw safety and more seumas2 has about 400 videos on viyoutubeJPEG Image - 308.45 kB - 04/14/2018 at 00:06 |
hot water lines in the insulation 019.JPGused a straight edge with the routerJPEG Image - 607.21 kB - 04/14/2018 at 00:05 |
hot water lines in the insulation 037.JPGsimple INNOVATIVE router idea by George KJPEG Image - 524.57 kB - 04/14/2018 at 00:02 |
passive 66 001.JPGused a router with an 1in./25mm bit to channel in the water lines, blue coded for the cold/ red coded for the hotJPEG Image - 643.29 kB - 04/13/2018 at 23:59 |
passive 66 003.MTSvideo shows how the insulation under the concrete pad is laid and sealed to R 50 plusmpeg-tts - 32.44 MB - 04/12/2018 at 22:16 |
00001.MTSbase for the foundation pad, setting the rough plumbing linesmpeg-tts - 27.19 MB - 04/12/2018 at 01:35 |
00000-003.MTS3 ft by 6in footing, 32in by 8in foundation walls, 915mm by 152mm, 812mm by 202mm, insulation on the pad is R- 50mpeg-tts - 24.94 MB - 04/12/2018 at 01:21 |
