Tutorial Difficulty: Intermediate
Time Required: 30 minutes
Required Materials:
• The Omega
• Any Dock
• A USB Storage Device
Useful Experience:
• Installing packages with opkg
• Using BitTorrent
• Using Transmission
• Using the Console
Because of the Omega's limited storage, we'll need an
external drive in which to place our downloads. Follow these commands on
your Omega Console to mount the drive.
1-A) Plug in the USB Storage
1-B) Usually, it will get mapped to the sda1 device. Double check the mapping:
ls /dev/sda*
1-C) Create a mount point directory
mkdir /mnt/sda1
1-D) Mount the drive, using 'mount <device> <mount point>'. For example:
mount /dev/sda1 /mnt/sda1/
The storage can now be accessed at /mnt/sda1
1-E) To safely remove the drive, use 'umount <mount point>'. For example:
umount /mnt/sda1/
For the purposes of this guide, let's assume the USB device was mounted to /mnt/sda1
Because of the Omega's limited memory, we need to setup a
swap file on the USB storage to extend the available memory. Follow
these commands on your Omega Console to setup the swap file.
2-A) Install the required package
opkg update
opkg install swap-utils
2-B) Use the dd utility to create the file that will become the swap
file.
The dd utility can be dangerous if used incorrectly
We'll need a client to download files via BitTorrent;
Transmission works well on OpenWRT so let's install the daemon as well
as the web interface packages:
