BinarySwitchSleepSensor.zipThe Arduino code for the Door and button sketchZip Archive - 3.64 kB - 08/22/2016 at 23:54 |
MySensors door and button_bb.pngPicture of schematic in fritzingPortable Network Graphics (PNG) - 105.74 kB - 08/22/2016 at 23:54 |
fzz - 6.87 kB - 08/22/2016 at 23:53 |
x-xcf - 293.55 kB - 08/22/2016 at 19:34 |
Portable Network Graphics (PNG) - 169.32 kB - 08/22/2016 at 19:33 |
Node Red flows.zipCollection of essential and sample Node-Red flows (flowchart programs in Node-Red).Zip Archive - 141.14 kB - 08/22/2016 at 18:26 |
MySensors Temp recorder.fzzOpen with Fritzing and see how everything is wired together.fzz - 11.32 kB - 08/22/2016 at 16:00 |
fridge_sensor.zipThe Arduino code for the Refrigerator/Freezer sensor, so you don't spoil foods, ever!Zip Archive - 992.00 bytes - 08/22/2016 at 15:59 |
MySensors Temp recorder_bb.pngThe picture of the Fritzing wiring.Portable Network Graphics (PNG) - 107.88 kB - 08/22/2016 at 15:59 |
FastLED_Node.zipArduino code to program the FastLED(Neopixel) Node. Can make strand of lights do all sorts of cool stuff.Zip Archive - 2.19 kB - 08/22/2016 at 15:29 |
bad IoT example.pngThe Bad IoT company's network topology.......Portable Network Graphics (PNG) - 290.03 kB - 08/16/2016 at 04:02 |
mosquitto.confReady-built configuration fileconf - 32.27 kB - 08/16/2016 at 03:27 |
Linux Mosquitto Config.txtHow-to for setting up Mosquitto.plain - 892.00 bytes - 08/16/2016 at 03:27 |
Arduino Nano MySensors Gateway.pngPretty Picture for those of you without Fritzing!Portable Network Graphics (PNG) - 201.35 kB - 08/14/2016 at 19:15 |
Arduino Nano MySensors Gateway.fzzCircuit diagram to connect a Arduino Nano (clone) to an nRF24L01+ for use with the SerialGateway in MySensors library - uses Fritzingfzz - 5.62 kB - 08/14/2016 at 19:11 |
Linux Tor Service configuration.txtThis is the guide to install Tor on your Linux machine, and how to set up the appropriate Hidden Services for SSH, Node-Red, and Mosquittoplain - 2.59 kB - 08/14/2016 at 18:38 |
Linux DNS Resolver for Onions.txtThis HowTo is for makiing a Linux system be able to seamlessly handle [hash].onion addresses from the system resolver. This means that any program can use an .onion without having to mess with proxies and the like.plain - 1.79 kB - 08/14/2016 at 14:40 |
