IoT Door sensor
A project log for Multisite Home/Office/Hackerspace Automation
Toolchain to start making your environments connected in a single cloud
joshua-conwayJoshua Conway 08/22/2016 at 23:580 Comments
For this, is a way to add a button actuator (for doorbell) along with a reed switch. Substitute one of the buttons for the reed switch - those magnetic thingies that act as a switch.
The code to put on the Arduino is here:https://cdn.hackaday.io/files/12985555550240/BinarySwitchSleepSensor.zip
