Making the actual hardware...
A project log for Pressure Regulatory system for Solar Plant
In this project I am going to automate the pressure regulatory system for a solar plant for community cooking and water heating
krunalKrunal 08/15/2016 at 10:300 Comments
After testing the code on these hardware prototypes, I designed my customized hardware. The schematic is provided below.
To be mentioned:
1. I used switching regulator LM2596 as linear regulator was getting heated up a lot.
2. The interrupt pin of W5100 is connected to interrupt pin of Arduino.
3. Added buzzer for when there is any problem, buzzer will be made ON.
4. Used ADM2484 as RS485 transreceiver IC.
The schematic file can be downloaded from "Files" section.
