CMOS Game of Life
A CMOS/VLSI implementation of Conway's Game of Life for an 8x8 LED matrix
The goal of this project is to create a hardware implementation of Conway’s Game of Life on an 8x8 LED grid. This chip is designed in a 0.6 µm CMOS process to be fabricated on a 1.5 x 1.5 mm 40-pin MOSIS “TinyChip”. The CGoL implementation has one standard start configuration, R-pentomino, as to limit the size of the hardware needed.
The chip consists of both custom and synthesized components. A custom register file was designed as to suit the needs of the project. The remaining components were synthesized from Verilog.
The chip has been verified in simulation. Currently, Evan and I are waiting for the chip to be fabricated.
Yann Guidon / YGDES wrote 10/26/2016 at 01:04 point
Yes, beautiful, I'm still waiting for updates !
Shaos wrote 10/25/2016 at 23:23 point
1st of all - Wow :)
2nd of all - Which software did you use to design this thing?
Vaibhav Viswanathan wrote 10/26/2016 at 01:06 point
Thanks!
We used Cadence!
design support
Project Owner Contributor
LED RGB Lamp
rawe
