Tutorial Difficulty: Intermediate
Time Required: 25 minutes
Required Materials:
• The Omega
• The Expansion Dock
• Onion BLE
• USB Hub
• USB Audio Soundcard
• Speakers or Headphones (Something to test the audio with)
Useful Experience:
• Using BlueZ
• Using PulseAudio
Since the Omega only has one USB port, we need a USB Hub to connect the BLE Dongle and USB soundcard. The sound card is where you will provide the auxillary output to the speakers.
After you are done this, make sure you are running the latest version of the Omega's firmware:
oupgrade
2
Step 2
Installing Packages
Here is the list of packages we will be using:
obluez-libs
obluez-utils
opulseaudio-daemon
pulseaudio-profiles
pulseaudio-tools
alsa-lib
alsa-utils
Before we start installing any packages, we need to run the following command.
opkg update
Then run the following command to install the packages:
PulseAudio is somewhat unpredictable in this
regard. If you have trouble, we recommend rebooting and restarting the
process. To check if PulseAudio successfully daemonized, run the ps
command, which will run PulseAudio:
I am planning a similar one. Can someone tell me what are the other Bluetooth options? I dont want to use bluetooth dongle, I want something which works with spi or I2C however the audio should be piped through the omega so I can use the I2S output to have great dac.
Hi,
