08/19/2016 – Ending soon...
A project log for Automatized Hydroponic Vertical Crop
Ideally, Stablishing an underground crop based on hydroponic technology and controlled through genuino to sustain a plant storage.
roberto-vicente-romeroRoberto Vicente Romero 08/19/2016 at 17:010 Comments
Deadline is closing by.
The funnel was already printed for the time we arrived at the lab, so we put it on its place.
Printed Funnel at the end of the prototype
Today, we turned on the laser cut machine to carve the HGC's box pattern. We expected to screw the Genuino controller inside it and we'd place the box close to the tank and the prototype. Thus, environmental sensors'd be placed on the outer face of the box, next to the prototype. The water sensor'd be submerged inside the tank.
We have also set up the entire structure, provisionally supported on a rack (the support structure and the water circulating structure).
HGC's box. Almost assembled
HGC's box empty but assembled
HGC assembling process
HGC box's right side. Seeing microSD converter and relay board
On Monday we'll put everything in place!
