Tracker Payload and LoRa parameters
A project log for Off-grid GPS (race) tracker client and server
GPS tracker map server and client for use in remote locations with no internet coverage or mains power.
stevesteve 08/22/2016 at 20:370 Comments
Payload
Device ID: 1 byte (0-255)
(Latitude: 3 bytes (0-90 degrees represented by a signed (3 byte integer) gives ~1.1m resolution at 56 degrees
Longitude:4 bytes, ( 0-180 degrees represented by 4-byte signed integer)
battery level: 1 byte (3.3-4.5v mapped onto 0-255) - probably overkill resolution
Speed over ground 1 byte (0-63.75kph mapped on 0-255)
COG - 1 byte 0-360 mapped on 0-255
#satellites (4 bits) of one byte
#valid fix (1 bit) of one byte
#panic button (1 bit) of on byte
# gpio flags 2 bits spare
Total 12 bytes
LoRa Parameters
With a set of 'long range' LoRa parameters (SF=10, BW=125kHz,CR=4/8), implicit header and a 12 Byte payload, the time on air is 280ms (610bps equivalent bit rate).
