close-circle
din rail housing for Pi Zero
My second try of a simple and cheap din rail enclosure + protoboard for the PiZero
close
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This simple project (pcb and enclosure) will help you to put a Pi Zero to a cabinet. The pcb includes a simple switching voltage regulator to convert DC voltages between 9...35V into 5V for the Pi Zero. The breadboard with marked and connected GPIO pins are is useful to add relays or circuit to your project.
