Log 7 - First run, it works
A project log for Automate the art
An automated version of Petros Vrellis's knit art
shlonkinshlonkin 11/19/2016 at 12:214 Comments
I finally got the bugs worked out of the machine and software and felt confident to do a full threaded run. I was half expecting something to go wrong during the 3.5 hour process, but it just worked.
I was thinking of making a time lapse video of it, but since the thing is rotating swiftly the picture would just be a grey blur. Anyway, here is the video.
And the result is
This does not look as good as it should. The parameters for line calculation need to be changed quite a bit and I accidentally ran the calculation for 200 radial pins instead of the 207 on the actual loom. That's why there are seven pins on the right side that are empty and the face is stretched out noticeably.
But I learned so much from this run that the next one will certainly look better. Here are some things I learned:
I'll let you know once I get the next one done. Here are some more pictures.
davedarko wrote 11/19/2016 at 16:21 point
Great work :)
shlonkin wrote 11/20/2016 at 11:40 point
Thanks.
Eric Hertz wrote 11/19/2016 at 14:10 point
Slick. Time-lapse would be cool to see... Maybe mount the camera on the hub and spinning? Or set it up to take a picture with each rotation?
Anyways, pretty awesome!
shlonkin wrote 11/19/2016 at 14:18 point
Thanks. Taking a picture each rotation would look pretty cool. If I find time I'll look into it.
