Hello again :-)
Apologies for my late reply. Winter can be a challenging season for those with inept immune systems.. :-(
While I overcame my health hurdles, in my last blog update you may recall I was to make attempt at building Ohm pre-production boards? Well, turns out the PCBs that I had received were indeed of an inferior quality :-( So I am now in the process of moving my Ohm board design to another PCB house..
Now, while that was all going on, another major thing happened.. I basically had another crack at building a pi zero sized FPGA devboard again. Here's the result - (re)introducing my 'Flea Ohm' board! :-)
.. and here it is running a test configuration in the shape of the Minimig core:
So.. now it looks as though I now have two possible designs to explore further (ie. Ohm and as-yet-unnamed Ethernet variant :-) Time permitting, I hope to do a small run of one or both boards (depending on interest) in the near future.
Thanks for reading! More to follow..
Valentin.
Hi Valentin,
Wondering how many layers these boards are and what is the trace/space sizing
Cheers - mark
Hello Mark,
I use four layers (and attempt to optimize the heck out of them as one does :-) on my current creations but I am toying with the possibility of going to six or eight layers. Also, I alternate (depending on the board) between 3/3 and 4/4 mil. track/space. Cheers.
Wow, the Flea-zero board looks really sweet! Quite the squeeze you put on that FPGA, I am sure it must have been a joy to route. :-)
Hey Xark, long time no chat :)
Thanks. You're right, redesign of my board using the larger ECP5 FPGA package style very nearly didn't make the final cut..
Cheers, Valentin.
Hi Valentin,
I'm really happy to see this zero ohm board back again. What kind of memory did you put ?
When can we hope to see those board available ?
Thanks for this excellent work.
Hello! Thanks, I'm glad it came back too :-) To keep things simple and low-cost (not to mention compatible with existing HDL examples), I decided to stick with SDRAM. On the prototype pictured in the blog I have a 32MByte DRAM installed. I have made some other improvements to the Ohm board i.e. like 12 LVDS lanes broken out instead of only eight at the GPIO as well as a more familiar connector layout..
In the longer term, I may try for a DDR RAM variant - if I ever figure out how I can make it all fit on the PCB that is (thanks to the relatively huge FPGA package compared with before..).
I have successfully tested the new prototype pictured above and so I can now move towards a small production run of boards. With luck, this could begin as soon as late next month. More details to follow..
Cheers, Valentin.
PS: On my larger Ethernet-enabled board (of which I am thinking of calling the "Giga"), I went for 128MBytes of low-voltage SDRAM.
