More details and an attempt at 1080p.. :-)
A project log for 'Flea Ohm' FPGA Project
My attempt at making an FPGA experimenters board in a popular form factor :)
valentin-angelovskiValentin Angelovski 08/10/2016 at 11:060 Comments
ello again :-)
Just a quick update on my Ohm project.
1.) Thought I'd release a little more info about my FleaFPGA Ohm board! Following is an overview of the FleaFPGA Ohm board in it's final physical layout:
2.) For fun, I made an attempt at getting 1080p (30Hz) video output from the FleaFPGA Ohm:
Worked better than I had expected! Unfortunately, it seems that 1080p30 does not appear to be a common supported screenmode among modern TVs. However, 720p60 and 1024x768 appear to work fine..
More to follow.. :)
