Hidden Pi In a Disk Drive
This is a hidden Raspberry Pi Hidden in the disk drive of your computer.
Its easy a Pi (Nice pun right) its a wast of time unless you want to have a computer with in a computer. I would say the best use for this is a server, tor node or a media box that you don't want seen. Its great if your Dad or Mum is the kind of person who checks you computer for stupid shit or just uses you computer because they don't want to pay for there own. Warning use as much wireless technology as possible. I would say the best use for this is a server, tor node or a media box that you don't want seen.
I used an old pc that probably came from the tip(Dump) because I got it for free and I also couldn't do this with a new computer because I only have laptops. So pretty much these parts are old AF.
  • 1 × HDMI Cable
  • 1 × Micro USB Cable
  • 1 × Computer With More Then One disk Drive Slot So you can still have a disk drive.
  • 1 × Disk Drive
  • 1 × Screen
  • 1
    Step 1
    Pretty much all you want to do is hollow out a disk drive I used a large one because it fits a raspberry pi better.
  • 2
    Step 2
    Then I opened the disk drive a bit so when I placed the pi inside the disk drive could still function but with out being able to read disks.
  • 3
    Step 3
    After that I place the cables out the back of the disk drive and then put the disk drive back together and then screwed it back in the the tower.
View all 4 instructions
