No analog read neaded
A project log for Water Temperature Arduino GPRS
Messuring water temperature with ds18b20. Sending it all to thingspeak.
marin-bMarin B. 08/12/2016 at 05:590 Comments
I just noticed there is no need for the voltage devider for mesuring the battery voltage.
The GSM module has a internal mesurment system you can call up using AT+CBC command
it returns the value for percentage of the battery and in mV.
Soon new code.
Thinking of using the adafruit FONA library.
