DIY Knit
Software to create your own Knit-like string pictures.
Public Chat
I created 2 programs that lets you make your own "Knit" pictures.
Based on the description of how the algorithm for the original Knit pictures works, I created my own algorithm that takes an image and converts it into a string picture.
Knit_Generator.exe can convert images to string pictures and exports the instructions.
Knit_Instructor.exe can open the instructions and tells you how to string the frame.
https://drive.google.com/open?id=19rcw84hp6OVy7-0c_rH_Gss5SRGS3Bu5
  • Settings explained
    Raphael Schaafa day ago 0 comments
    Since I get some questions about the settings from time to time I thought I'd explain them a bit better:
    Radius:
    The radius of the circle in pixels. Does not have any connection to how large you want to make the actual portrait. A bigger radius will make a more precise portrait, but will also take longer to compute. Use a small radius for quick previews and a bigger one when creating the final instructions for your portrait.
    Hooks:
    The number of hooks or nails you will use. More hooks make for nicer portraits with less geometric artifacts, but take longer to compute. Keep in mind how close together you can fit the hooks/nails.
    Lines:
    The number of lines that will be drawn between the hooks. Good values generaly between 2000-3000. When the generating process is near its end and all the new lines are placed around the border of the ring you have too many lines. When they are still being placed through the ring you have to few lines. Try to find a good balance.
    Contrast:
    The most tricky one to figure out. Basically the value that gets subtracted from every pixel when a line passes through it. A higher value should be used for thicker threads or smaller portraits. 20-50 seems to work fine.
    Scale:
    Zoom in and out of the picture with 1 & 2.
    Offset:
    Move the picture with the arrow keys.
    Detailled view:
    To open & close a more detailled view of what is going on during the generating process press D. This will show all the lines calculated so far and the remainder of the source image. Will slow down the calculation imensely, so don't leave it open.
View project log
  • 1
    How to use Knit_Generator
    1. Open Knit_Generator.exe.
    2. Press Space to load an image (.png, .jpg, .bmp should work).
    3. Position the part of the image you want converted inside the circle using the arrow keys to move it and 1 & 2 to scale it.
    4. Set the number of hooks, radius of the circle (bigger = more accurate but slower calculation), number of lines and contrast (contrast is inverse, higher number will create a flatter image).
    5. Press Enter to start the calculation (takes a couple of seconds to initalize).
    6. Pressing D during the calculation switches the drawing of the lines on and off. Can be used as a preview, but will slow down the calculations extremely if left on.
    7. When finished, press S to export the generated image as an .ini file containing the instructions for assembly.
  • 2
    How to use Knit_Instructor
    1. Open Knit_Instructor.exe.
    2. Press O to open a previously generted ini file.
    3. A single line will be displayed at a time, with the instructions from and to which hook to connect the string.
    4. Cycle through the steps with Enter and Backspace.
    5. Use J if you want to jump to a specific step.
    6. Use T to toggle the Image on and off.
View all instructions
idisc wrote 10/21/2019 at 08:48 point
Proof of concept. Here are two thread portraits I made of John Lennon https://imgur.com/q5PShL6 and Alexander the Great https://imgur.com/NzFcZMs Thanks Raphael.
Gerben wrote 10/21/2019 at 15:29 point
Looks very nice. Thanks for sharing.
Raphael Schaaf wrote 10/26/2019 at 02:17 point
WOW! That's awesome :D
I just bought some of the materials for my first string portrait. I want to make a self portrait :)
idisc wrote 10/28/2019 at 17:45 point
I used a 39 centimeter wooden disk from an IKEA lazy susan and painted it with matt white paint. A CNC was used to evenly drill holes into the wood. Appropriate brass nails were used. I numbered the nails from 0 to 199 with adhesive paper labels. The lazy susan was left on the base to make it easy to spin to the appropriate nail positions, and the lazy susan was removed upon completion. Hope this will make construction easy.
Raphael Schaaf wrote 10/26/2019 at 03:19 point
Can you tell me how similar they are to the preview generated by the program?
idisc wrote 10/28/2019 at 17:36 point
The results are similar, however you have to have extreme contrast (black on white) and where black becomes too invasive you can mask the area and apply a light coat of white spray paint to soften the excessive black.
idisc wrote 11/08/2018 at 14:55 point
Rafael,  Do you have plans to create the DIY knit for a square shaped knit?
Raphael Schaaf wrote 04/14/2019 at 20:42 point
It wouldn't be too difficult to do, but I'm not planning on investing much more time in this project
Gerben wrote 04/15/2019 at 15:23 point
I've tried squares, but they don't look . At least in simulation. You get some weird "interference" patterns. It also looks more geometric/blocky, instead of the more organic results you get with circles. Same for hexagons, though not that extreme. Circles tent to look the best, somehow.
Here's my semi-finished online "knitter": https://gerben.algemeenbekend.nl/threadtone/
Where you can select multiple shapes.
Raphael Schaaf wrote 04/21/2019 at 08:42 point
@Gerben Wow that's really interesting!
As far as I can tell the main problem with squares / hexagons / etc is that there will never be a jump to a hook on the same edge, which severly limits the number of options for a jump, on a square you get 25% fewer hooks as an availlable target.
The second problem that I can see is that the diagonals will always have the highest weight / priority, since there will be the most pixels between them, which causes them to be favored over other hooks.
Maybe one way to partialy fix these problems would be to only use a circular image, even when you have a square frame?
Gerben wrote 04/21/2019 at 12:47 point
@Raphael Schaaf  No sure if that first one is really a big issue.
As to the second problem you mentioned. On a circle, lines to the direct opposite are preferred to more diagonal lines, as those lines are shorter. I've experimented a bit with dividing the total number of black pixels on a line, by the length of the line, to negate this effect.
The downside was that the algorithm then preferred very short lines. I think I added a minimum length or something, which had the funny side-effect of  creating a second circle, a fixed offset from the edge. I think that's where I stopped, as other projects got priority.
Never really finished it. It seems pretty much everyone only does the software side of this project. I've only seen 2 projects with finished string-art.
PS I even made a page, that would speak the number of the nail that was next, so all I needed to do was press "next", an listen where to go next. (-:
chaterrony wrote 08/03/2018 at 17:04 point
I was so fascinated by your pictures, that I did an app for Android which does the same. Reason: I have no windows... (hope that my 2012 iMac dies soon to be able to purchase a windows machine again)
BUT! The power of a tablet of smart phone is so little, that it takes decades to calculate... My "longest" try was with 50 strings and it took 5min! :-( So I abandoned this.
But my question (as I didn't got as far to be able to test it myself): You check the darkest connection from a certain point to all other points. The darkest is taken. What do you make next? Do you just go to the next point  and do the same calculation (this is the way I did it)? Or do you have another system how to pick the next point to check the next connection?
Raphael Schaaf wrote 08/06/2018 at 07:24 point
Hi, that's cool, what did you program the app in?
You're right, the point you arrive at is taken as the new starting point for the next check.
It's a very time consuming calculation, if you are able to use the GPU it could probably run much faster...
chaterrony wrote 08/07/2018 at 20:56 point
So, please don't block me immediately when I tell you how I programmed it... It's on "ai app inventor". I am trying to work with Visual Studio, but it's quite a hard start as a newbie... One day... who knows :-)
I'm for sure disappointed on the functionalities of this software (usually I work with Arduino, and even the Arduino IDE is better!) and the programming by moving blocks...
I have modified the app and I have shared it on the appinventor website: ai2.appinventor.mit.edu/?galleryId=5560843821514752
Anybody who has ideas/suggestions how to improve the code is very welcome to let me know! Thanks in advance!
Raphael Schaaf wrote 08/08/2018 at 07:16 point
That's cool, I started programming with the block functions in Game Maker :D
I still use Game Maker to this day, even for this project, but nowadays I use the built in scripting language :)
Khalid Khattak wrote 05/17/2018 at 03:36 point
Awesome superb program.. I am in fabrication of DIY embroidery machine.. All I want to get X-Y coordinate and connecting string numbers .. It will be really awesome to embroidered such patterns...
Raphael Schaaf wrote 05/24/2018 at 07:43 point
Nice, but you will probably need a piece of software to convert the instruction file to something that your embroidery machine understands :)
Khalid Khattak wrote 05/24/2018 at 07:57 point
Dear Raphael, in the past i wrote an embroidery program that convert DST Tajima file format into simple G&M code. You can see in the following video.
I just need your help in this... end coordinates of connecting lines...
https://www.youtube.com/watch?v=5IKwKiq_b7w
unaiaroza wrote 04/28/2018 at 20:47 point
Can I load the exported file into cura and print it with a 3D printer?
Raphael Schaaf wrote 04/28/2018 at 22:19 point
No idea what cura is capable of, but I highly doubt it...
unaiaroza wrote 04/28/2018 at 22:59 point
So what is this app functional for?
Stefan May wrote 04/23/2018 at 05:16 point
Would you like to share the algorithm used?
Raphael Schaaf wrote 04/23/2018 at 06:54 point
Hi, I can do that, probably in a log sometime this week...
crowe.gabriel wrote 04/22/2018 at 20:37 point
https://imgur.com/a/kY50fKE
I've compiled this for linux, using the YYC for greater speed and it runs, BUT space does not bring up the dialog. It wont work because this:
https://docs.yoyogames.com/source/dadiospice/002_reference/file%20handling/file%20system/get_open_filename.html
and it says this about it:
"NOTE: This function is only valid on the Windows and macOS targets"
You might need to revisit this for linux compatibility, because this is a blocker for linux people.
crowe.gabriel wrote 04/22/2018 at 20:52 point
I faked it by commenting this line and and linking straight to the  file
//f = get_open_filename("image file|*.png;*.jpg;*.jpeg", "")
f = working_directory + 'template.jpg'
https://imgur.com/a/xtgSeU9
Which you can replace in the assets folder 'template.jpg' gets loaded when you tap space, instead.
I will have more time to fiddle with this (and provide linux executables) in a couple days.
crowe.gabriel wrote 04/22/2018 at 21:38 point
Found another issue: the same technique is used to save the file upon pressing S. This wont work on linux either, unfortunately.
Perhaps upload it like this?
https://github.com/ClockBotGames/Game-Maker-Pastebin
Raphael Schaaf wrote 04/23/2018 at 06:48 point
Oh, I didn't know get_open_file() was windows only...
Let me know if I can help you with this :)
AlanGreen wrote 04/21/2018 at 16:22 point
Hi, Awesome project! But I have problem with the step exporting generated image. Instead of a jpg file is saved after pressing S but a .ini file. What should I do? Thanks!
Raphael Schaaf wrote 04/23/2018 at 13:51 point
That's what the software is supposed to do...
sani.nassif wrote 04/18/2018 at 17:31 point
Any chance of getting a Mac or Linux version of this algorithm?
Raphael Schaaf wrote 04/18/2018 at 18:46 point
I wrote this program in GameMaker Studio, and there seems to be an export function for Ubuntu and Mac. I can give it a try...
Raphael Schaaf wrote 04/18/2018 at 18:57 point
No, sorry, I just checked and I don't have the necessary licences to export for Linux and Mac...
I uploaded the source code to the Google drive, so if anybody has the necessary GameMaker Studio licences they could export the program for me.
sani.nassif wrote 04/18/2018 at 19:16 point
I hope someone out there can help. Kudos on a nice project!
Leonard wrote 04/19/2018 at 23:21 point
Are you using the original GameMaker Studio? If so I have the Mac License.
Raphael Schaaf wrote 04/20/2018 at 14:17 point
Yes I am, GameMaker Studio 1 or whatever you wanna call it :)
crowe.gabriel wrote 04/22/2018 at 20:58 point
I have found some issues and i'm building one, see comments above.
Raphael Schaaf wrote 05/03/2018 at 14:25 point
Have you tried to run it with wine?
Dr. Cockroach wrote 04/17/2018 at 12:53 point
having some problems but most likely my Win7Starter. When data is saved, where is it stored. The Instructor crashed my whole system the first time but loaded on the second try. I really want to get this working as it is neat as heck :-)
Raphael Schaaf wrote 04/17/2018 at 14:42 point
Oh, that doesn't sound very good...
I tested it on a couple of different PCs and had no problems...
After you run an image through the generator you hit S and can choose the location where you want to save the data.
If you have problems with the generator I recommend reducing the number of lines, hooks and the radius to smaller numbers (~50), just to see if it works at all.
The higher those numbers are, the longer it takes to calculate.
Dr. Cockroach wrote 04/17/2018 at 23:34 point
Thanks Raphael for the input. I will try again later this evening :-)
Dr. Cockroach wrote 04/18/2018 at 08:35 point
Here is the actual issue ( I think ). The Instruction program is working as your Test INI file works well... However when a file is loaded into the Generator then there is no action when selecting the Save option. I have reduced all the variables and the program just continues to cycle through the Fps line in the upper left.
steve wrote 04/17/2018 at 08:44 point
trying this out myself, thanks for this! the instructor will be fantastic to use to create my own IRL
Raphael Schaaf wrote 04/17/2018 at 11:19 point
Cool, please send me a picture when you're done :)
I have yet to make one myself...
Dr. Cockroach wrote 04/13/2018 at 16:40 point
Whoa is right, This is really something to try :-)
Mike Szczys wrote 04/13/2018 at 16:33 point
Whoa! I love this. That string art was fascinating when we covered in on Hackaday a couple of years back. It's really cool that you implemented an algorithm for this and the sample images look fantastic! Well done.
Raphael Schaaf wrote 04/17/2018 at 11:18 point
Thanks for the compliments :)
The base image used really makes or brakes the end result.
I tried a bunch of variants for the algorithm, but surprisingly the results mostly looked the same...
