Wearable computer
A wearable computer based off a raspberry pi and a hacked monocular display
This project has several components, each of which might potentially be its own project:
1) The modded monocular head-mounted display/goggles
2) The haptic glove interface
3) The dehumidification mechanism for the goggles
4) The software stack for implicit learning (via both goggles and gloves)
While this wearable computer is general-purpose, it's explicitly intended to be useful for always-on passive implicit learning. Building on Georgia Tech research into implicit haptic learning (using a glove augmented with vibrating motors to train muscle memory for learning to play the piano), I'm building a vibrating glove and a mechanism for automatically programming the pattern of impulses from a variety of sources (starting with midi files -> piano keyboard fingerings, and text files -> twiddler finger configurations). On the other hand, I am using my clone of JWZ's 'xsublim' program to constantly prime myself with random wikipedia and rosettacode articles. I additionally have a speech-enhanced speed-reading program and a ZigZag-based information organizer.
While the goggle-based mount for the HMD looks cool and is fairly structurally stable, there's a major problem with fogging (because I sweat a lot, especially with warm electronics strapped to my skull), and so I will probably need to build a dehumidification system. I believe that I can make a solid-state system for pumping air through using a selectively sealed heat sink and a peltier junction, but this is currently only on paper.
I initially intended to use a 'cobbler pi' for interfacing to the haptic glove. However, I switched prototypes to a more flexible glove and decided to dedicate an arduino to the task. Because of this, I should be able to use the Pi to program it and allow the program to run independently on the glove (for midi input, and possibly for other configurations); furthermore, I can program the glove and power it externally to use it when I am not using the other parts of the computer. Additionally, with this I gain a bunch of nice ADC pins, with which I can read resistive bend sensors or other analog instrumentation, then pass along these readings to the Pi over FTDI.
  • 1 × Raspberry Pi
  • 1 × USB battery pack
  • 1 × Video glasses https://www.adafruit.com/products/1452#Technical_Details
  • 1 × Twiddler 2.1 http://tekgear.com/keyboards/chording-keyboards/twiddler.html
  • 1 × Goggles http://www.adafruit.com/products/1577
View all 8 components
View all 2 project logs
  • 1
    Step 1
    Remove the large plastic visor from the video glasses.
  • 2
    Step 2
    Disassemble the primary unit of the video glasses, which now resembles a black plastic bar.
    You should end up with two boards connected by a thin-film ribbon cable, one of which is connected to another board (containing a USB-like plug) connected by a small white socket and a bunch of multi-colored wire. Each of the larger square boards should contain a display on the bottom, probably with plastic spacers. Remove and discard the spacers (which will probably be screwed in), and remove the display that lacks the white plastic socket.
    You should also end up with two small black lens housings with lenses in them, and a black plastic backing.
  • 3
    Step 3
View all 10 instructions
Jasmine Brackett wrote 08/05/2014 at 22:54 point
Hello John, just a heads up that you need to add a few things to be considered for the next stage of The Hackaday Prize. You must have the following by August 20th.
- A video no more than 2 minutes long on YouTube (or Youku).
- A link to your video on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
There is a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
