Surrender
A project log for My Dalek Build
For next Halloween I want a Dalek for "Trick or Exterminate"
agpcooperagp.cooper 10/18/2016 at 02:350 Comments
I Surrender
I finished coding the motor/sonar board and tested the software.
I used serial print and the built in LED to indicate the sonar and command/motor status.
The sonar and motors work as expected separately but when combined too many false sonar triggers.
I am wondering if motor noise and/or vibration are triggering the sensors?
The ESP12-E is not that stable as well (it can stop working) suggesting electrical problems still exist.
Many months ago I had a remote control test bed that worked fine.
I have spent months trying to get the HC-SR04 working with the test-bed.
It seemed at the time adding sonar would be a small job.
What when wrong? I still don't understand!
Yes, the steppers somehow destroyed four HC-SR04s.
The servo certainly did take out two HC-SR04s and a 6.2v 1W zener (lucky it did not take out everything).
Learnings
Anything inductive needs special attention to the power supply, you have to consider inductive kick-back.
Better to build a separate motor controller and even a separate motor power supply.
Better to delegate software duties (i.e. use a master-slave setup) as managing everything on one MPU is difficult (particularly the ESP-12E).
Find a replacement for the HC-SR04!
I will return with a new plan of attack but after Halloween, AlanX
