Testing OpenMV2 (STM32F429)
A project log for OpenMV
Python-powered machine vision modules
iabdalkaderi.abdalkader 07/17/2014 at 02:492 Comments
Finally worked up the courage to build this one :) after hours of assembling, testing, hacking the code, debugging, probing etc.. I finally managed to run the first script :)
This one has everything OpenMV1 has plus an SDRAM, 2 IR LEDS, 2 servo headers, a power management chip, and 20 I/Os... Here's a closer look at the sensor block:
I ordered a few sensor chips weeks ago, but still haven't received them yet, I couldn't wait any longer, so I took one out from a sensor/lens package,  it looks like I tore off some pads while desoldering it, now I'm forced to wait for the sensors before I can do further testing :(
Leonardo wrote 09/11/2014 at 15:32 point
Hello, how do you solder cmos sensor?
i.abdalkader wrote 10/05/2014 at 13:21 point
I just place tiny solder blobs on all pads and use hot air, while you're heating the sensor give it a nudge in any direction it will snap back to place, this is a good sign.
