• Log of the Day : 17/05/2018
    Jules Renaudat6 days ago 0 comments
    Today we received the tensiometer which is kind of old school and we realised it would be hard to trick it so has it would work with the Arduino Card.
    However, we advanced on the project, the connections that you can see on the picture below
    We got a small problem for inputing the code on the card.
    The next step is to input the code, then we'll check for the tensiometer which needs some physicals modifications.
    End of the log
  • Log of the day 03/05/2018
    louis.salfati05/03/2018 at 10:52 0 comments
    We received the components to create the heart beat sensor.
    We ordered the tensiometer  because we forgot it last time.
    We wrote the code of the LCD screen and the code of the heart beat sensor.
    This is the trello to define the task : https://trello.com/b/ZAgzShXl/project
    We did the connections for the hardware.
  • 12/04/2018
    louis.salfati04/12/2018 at 14:33 0 comments
    We changed our project to an easier one, we passed from a Blood pressure sensor to a beating per minutes sensor.  But the BPM sensor is already existing and it’s not making such a change from produces that already exists. We decided to make both BPM and Blood Pressure Sensors with an Arduino Card. On this day we defined roughly what we needed as pieces for our project. We finished the session with the list of all our components, ready to order.
