1Step 1
This time some calculations for the correct volume and porting based on the sub-woofers I have. Cheating using the calculator at http://www.bcae1.com/spboxnew2.htm
2Step 2
Ended up with a good compact enough size and tightly constrained to the calculated parameters. Cuts fit on one plywood board.
3Step 3
Found my plywood board!
4Step 4
And a person to help make it fit in my car.
5Step 5
A few more items left to grab at the store. Total of ~$100 for all wood, glue, brackets, hardware, sandpaper, and finish. Dish soap and coke not included :)
6Step 6
Now time to make some more accurate cuts and smaller bits
7Step 7
A bit of a jump here to the case fitting together in the subwoofer section
8Step 8
Some space for the open-air mid-woofers and tweeters
9Step 9
Subwoofer chamber porting structured nicely and secured with contractor glue
10Step 10
Subwoofer face prior to finishing and additional sealing. Planning on countersinking the screw heads and using a cutoff tool to buzz off the oversize screws.
Nice, i think i'll try something like this with the spare speakers and woofers I have at home.
