I built a pinhole camera cap for my Canon T3i, so now I need a way to control exposure time. Goal is to build a nerdy device that lets me update firmware easily to control my camera. Also, to learn as much as I can about as many related things as possible:
I've wired everything up with my Atmega328P on a breadboard, including:
9V power supply through regulator
connection to LED panel
shutter release trigger to 3.5mm jack
rotary encoder
The encoder doesn't seem to work reliably, but I'm pretty sure it's a software problem. It's configured with INPUT_PULLUP in the code, and is connected to ground in the encoder itself, so it's probably not a voltage problem.
One thing missing so far is an interface to analog input. I may just wire that directly later. Just want to keep it simple for now.
I've put in an order to DirtyPCBs, but I named the files wrong in the ZIP. We'll see if that causes a problem.
