I've mostly populated the board and it works!
- Ended up replacing the power supply diode with a wire since I was having trouble with it. Will just be careful.
- Ended up leaving the reset button circuit unpopulated. Will just use the power switch.
- Haven't populated the transistor for the focus button switch. Will do that so the program can wake the camera before firing the shutter release.
I just need to design a case.
