Contrast enhancement with a diffusion layer
A project log for 4014 LED minimodule
A cheap, small module that displays two 7-segments digits with simple multiplexing
yann-guidon-ygdesYann Guidon / YGDES 09/06/2016 at 21:078 Comments
Since the beginning of the #DYPLED project, I've been wondering how to provide a better aspect with the least means. The display is nice as it is but it can still get better. Today I could finally test my hypothesis :-)
This is the display modules, shot with my crappy smartphone camera :
Adding a simple, dumb sheet of white paper in front makes it look like this :
This is obviously visually more pleasing, I think.
Now, there are many problems to solve:
I'll test more ideas, meanwhile, I'd love to read yours in the comments :-)
20160909:
I tried various diffusion sheets from broken LCD screens. The results are not as expected. LCD diffusors do their best to not waste photons and spread light as much as possible.
Paper OTOH absorbs quite a lot of light, which increases the contrast. I'll have to find a very thin adhesive label...
Alex wrote 09/07/2016 at 14:53 point
Nice! I would try the backlight diffusion layer  from old/broken PC-Monitors. Or clear acrylic sheets sanded with fine sandpaper
Yann Guidon / YGDES wrote 09/07/2016 at 15:06 point
New LCD have fewer diffusion layers and don't use translucent diffusion sheets... I know, I have a large pile of broken LCD screens from a repair shop, that I use for their backlight :-)
Anyway there are so many things to try !
Ted Yapo wrote 09/07/2016 at 02:26 point
If you're looking to improve contrast without diffusing (so you can see the inner workings, but also see the lit segments better), there are some other choices.  Clear color filters work great for contrast enhancement on colored LEDs but with white LEDs, colored filters don't work as well. On the other hand, a 50% neutral density filter will increase contrast by 2x: the light from the LED will only pass once through the filter, while ambient light will have to pass through twice, once in and once out.  "window tint film" used to darken car windows is cheap, self-adhesive, and readily available (around here, at least).  Darker filters increase contrast even more; the enhancement is T/(T^2) or 1/T for a filter of transmission T.  Of course, darker filters also dim the LED output more, so you have to strike a balance.
Yann Guidon / YGDES wrote 09/07/2016 at 02:42 point
Thanks for the feedback :-)
It appears that luminosity is not a problem because the LEDs are strong at 3.3V. Some attenuation is possible. Ideally, not too much, to save energy.
Still, it's not comparable to the TIL311's power consumption :-D
Yann Guidon / YGDES wrote 09/06/2016 at 22:51 point
I saw this nice stack already but I was more thinking along the lines of sticky tape or LCD panel diffuser or...
Something VERY thin and more durable than cellulose/paper :-)
K.C. Lee wrote 09/07/2016 at 00:22 point
Mylar® A (Frosted, Milky White Translucent) (aka Electrical Grade Mylar), drafting mylar, parchment paper (not to be confused with wax paper)
http://photo.stackexchange.com/questions/8371/what-are-the-best-and-worst-diffuser-materials-for-diy-softbox-light-tent
https://www.alibaba.com/showroom/light-diffuser-film.html
Yann Guidon / YGDES wrote 09/07/2016 at 00:45 point
Thanks ! I'll try to find adhesive versions :-)
